How to delete the references of an Item
After using save as of an Item in NX, the Item in Teamcenter is showing references to 2 other Item Revisions.
Any idea to delete those references?
Thanks in advance!
M
Re: How to delete the references of an Item
Which dataset are you using for save as operation, UGPART/UGMASTER?
Does impact analysis showing references to other item revisions by where used or where referenced?
Ganesh is right, that's one way to check what are the other items referenced to your item, from there you can decide to delete the reference...thanks.
