How to export old workflow template which is not available in WF designer?
Builder
Builder
Is it possible to export old workflow template which is not available in WF designer, but it is available on old item revisions, when we see in the workflow viewer. Any suggestions?
Re: How to export old workflow template which is not available in WF designer?
Good afternoon
I think you can try this through the plmxml_export utility, you need to find the root element of the template. This should be an EPMTaskTemplate and see its UID using the Print Object view
plmxml_export -u=user -p=password -g=dba -xml_file = "your_path\test.xml" -transfermode = workflow_template_mode -uid="uid_wf_template"
Builder
Builder
@ArthurRM,
Thanks, I have tried,but it exported item revision info as well
Do you accurately export the process template, not the completed process? These are different objects. I tried and I do not have any extra objects except the objects of the process itself
Builder
Builder
Thanks, Its working.
