How to generate BOM Report in a hierarchical way with query builder or TCRA?
Builder
Builder
Hi All,
Any suggestions?
Re: How to generate BOM Report in a hierarchical way with query builder or TCRA?
Siemens Genius Siemens Genius
Siemens Genius
Hi Swamy,
Try exploring File--> Print... (Contents / Application (HTML/Text)) from Structure Manager.
This will give you the complete BOM export with required columns.
Builder
Builder
@ArunG
Thanks. Is there any way to count BOM items?
From Structure Manager you can do Tools->Export->Objects To Excel
from the dialog you can choose your template from the list.
When you use this export you will get excel hierarchical report.
You can also customize your excel template to count items on the Open event using excel macro.
