How to hide quantity in bomline first column
Hi,all,
        i want to hide quantity in bomline first column,for example,x4 or x3.
        i find a preference ,ImanItemLine_bl_indented_title_expression,and try to modify the value from $bl_line_name+(If($bl_parent=NULLTAG,"",If($bl_quantity>"0",((" "+getLocalizedText("k_xSymbol")+" ")+$bl_quantity),""))) to $bl_line_name,but it does't work.Has anyone done this before?
Any suggestions will be appreciated~
Thanks!
Re: How to hide quantity in bomline first column
You can split that first column out by,
Right clicking the  grey area next to the text (BOM Line)
Then select Insert columns and add to the displayed columns and move to top;
Part Identifier
Revision
Item Name
Remove Bom Line
and then save this configuration
Matt
Unpack those BOM lines.
In the colum clic rigth, insert column(s), select columns name you want to displayed,
you can save as preference for user, group or site and all user can see the same configuration
Saludos,
