How to identify syslog name of a TC Session from Pool Manager
Hello Experts,
Is there any way from that someone can identify the syslog name of a teamcenter session from PoolManager session.
It is possible to see some part of the syslog in Pool Manager but not able to view whole syslog or identify name of teamcenter syslog.
Any input over this will be helpful. Thanks.
Sudarshan
Re: How to identify syslog name of a TC Session from Pool Manager
I think this will help if we can identify how syslog being generated mean how or from where the naming pattern of syslog file being derived.
What the logic being used behind the syslog naming can be handy.  the portion in start(*)
tcserver.exe     ********   .syslog
Sudarshan
You can find solution in the post "syslog name from TCserver process ID"
The process is version specific so I'm going to take the best case and say that you've installed the Teamcenter Management Console.
https://docs.plm.automation.siemens.com/tdoc/tc/12/help#uid:xid1256816:index_plm00102:id1683912:xid6...
Then you would:
Evaluating: AW 3.4
In the richt-client go to "Help" -> "About" make the window wider and look at the Line "Log File".
There you find the name of the session and the logfile.
Dirk
