How to install Active Workspace
Dear All,
Kindly give process of installation of Active workspace.
Is it install with TEM?
Irfan Pathan
3 REPLIES 3
Re: How to install Active Workspace
It is installed like a patch on TEM launched from Teamcenter installation.
https://docs.plm.automation.siemens.com/tdoc/aw/3.4/aw_html_collection#uid:xid1284832:index_Deployme...
I will try it.
Is there any few step & simple method\steps available for AWC?
The easiest way to install Active Workspace is to use Deployment Center.
https://community.plm.automation.siemens.com/t5/Teamcenter-Blog/What-s-New-Deployment-Center-2-0/ba-...
Evaluating: AW 3.4
