How to -kill a 2 Tier TAO window
When we first installed 2 tier we had assistance from Siemens to get everything up and going correctly. Since then, we had a hardware failure and had to reload everything. I remember the person from Siemens instructing me to add a -kill to a .bat file to close the TAO window when exiting TC. Does anyone know what file I need to add this to and where in the file to add it?
Re: How to -kill a 2 Tier TAO window
You can just close the TAO window. I think you're referring to another running command; fccstat.  There's something written somewhere that suggests adding a fccstat -kill or -stop command as part of a user's OS logoff script to minimize the occurrence of a corrupt FCC cache.
Larry Carpenter, P.E.
It may be fccstat... I searched around before posting the question and all I could find was fccstat results. I know in our previous setup, we added -kill to something that would automatically close the TAO window when I exit TC. I'm just trying to locate that something.
Thanks for the reply
You didn't say which version of Teamcenter you're on? In older versions of Teamcenter (Engineering), you could add a kill command at the bottom of portal.bat to close TAO when you closed Teamcenter. It doesn't work for newer versions of Teamcenter (Unified).
Evaluating: AW 3.4
We are on version 10.1.4
That's Tc Unified so you won't be able to automatically close the TAO window by including the command in portal.bat. You can create a script that you can run after closing Teamcenter but its easier to just click the X.
Evaluating: AW 3.4
You could use "taskkill" command. C:\Windows\System32\taskkill.exe
Thanks and Regards
Yogesh Fegade
