How to know / How to list all the Top Level Assembly Items? Using a Query? PLMXML?
Greetings to this awesome community!!
This is my first post and i have a Simple Question (But I find is not that simple..) about Top Level Assemblies in Teamcenter (11.4), so here are the question:
There's any way to know what is the TOP LEVEL assembly Item in Teamcenter?
I want to list all of the top level assembly items in my Teamcenter database and make a report, but i don't know if it's using a query or using PLMXML. I do some tests using anothers default reports as base but have no luck..
I made a query that list me every item with a BOMView but some of that items are sub-asm so it doesn't work either..
Can anyone help me with that?
Thanks a lot for your help!
3 REPLIES 3
Re: How to know / How to list all the Top Level Assembly Items? Using a Query? PLMXML?
I don't think their is a good way to do this with OOTB configuration as all BOMS are single level BOMS that can be part of a assy again. So TC does not see the difference between a TOP-level-assy or Sub-assy
I know some customers define a top-level-assy specificly with a other item type or attribute but also here it is not garuanteed that it is realy a top level.
The other method that could work is to write a custom report to do a where-used on all items to top-level and list the uniq items. we did this for a customer where they wanted to find all top-levels for a specific selection. i guess to do it for a whole database you will run into performance issues though.
not an expert but this is my experience, maybe someone else know a working solution ? :)
If finding all items that have children, but aren't referenced in another assembly then you can get there with Query Builder.
For imprecise structures you want to find Items with a BOM View, and that aren't referenced as a PSOccurrence child item.
The query will be similar to...
You will need to tweak this a bit for precise assemblies; Look for ItemRevision and check for structure_revisions not null.
Greetings!
That Works for me! i was testing this weeks and it list all of my assemblies in Test Environment.
Best regards!
