How to load the value of a PropertyDescription field on a Form using SOA API ?
Within the field 'SoaType' of a Form there is a subfield 'PropDescs' which contains the names of fields on the form, but not the values.
For ex. the field 'owning_group' contains the key 'owning_group' and the value '{Teamcenter.Soa.Internal.Client.Model.PropertyDescriptionImpl}', not the string containing the owning_group's name.
Rather the value exposes the PropertyDescription type members, ex. 'enabled, FieldType, InitialValue, Localizable, LovCategory' to name a few, but again, the actual value within the field is not present/or loaded.
Running DataManagementService.GetProperties on the WorkspaceObject representing the Form is not loading any additional properties, namely, Object_properties which appears to be the field desired in this case.
GetAttachedPropDescs2 documentation wording isn't providing clarity - "Get the attached property descriptor based on input type name and property names structure."
Is this meaning it takes an input type, ex. "ItemRevision", and ex. name "object_name", that the output would be "String" or the actual value stored in object_name?
Similarly, how does this method know which object to pull the data from?
tl;dr - Trying to find the value entered into a field on a given form and retrieve it. Is this possible?
