How to map Multiple templates for same cad type for solidworks
Hello Team,
I want to map few templates for the SolidWorks datasets,
For each dataset type (sldprt, sldasm & slddrw) I have multiple templates need to be mapped.currently
currently I can map one template for each dataset,
Ganesh
Re: How to map Multiple templates for same cad type for solidworks
Hi Ganesh
  Only one template is supported.
Note that these are ONLY used when you create an item with an empty Solidworks Dataset in the Teamcenter RAC and then send it to Solidworks.  This is a bit of an edge case.  These are not referenced when working from Solidworks and Saving to Teamcenter.
- Peter Heath - PLM Business Development Manager
ITI - Siemens Development and Solution Partner
