How to migrate bmide template to the correct version using the bmide client.
I am trying to upgrade my TC 8.3 test enviorment to TC 10.
Using AutoCAD, T4S, Catia Integreation OOTB templates and custom BMIDE template.
At upgrade database feauters TEM gives a status message "The following templates: [autocad, hhml, integration4catia, t4s, upgrade] have incompatible versions. To proceed with the database upgrade, please migrate these templates to the correct version using the BMIDE client or select the correct version templates."
How I can migrate thes templates or kindly help me with this.
Re: How to migrate bmide template to the correct version using the bmide client.
OOTB Templates :
Most of the BMIDE templates has been provided by Siemens PLM to proceed with your upgrade procees.
Ex : AutoCAD, T4S, Catia Integreation OOTB templates
So you need to download required templates with respect to upgrade TC version.[ Refer attached Snap ]
Custom templates ;
You have install upgrade TC version BMIDE Client to Upgrade your custom templates from prior TC version , before start proceeding with TC upgrade. [ For more information refer BMIDE guide to upgrade custom templates ]
Thanks for your quick reply. will surely do the same and revert.
