Do you mean
Reply
How to override "File->open"
For a particular dataset type the customer wants his own program to be called. How can this be achieved ?
As per a GTAC solution,
1. OpenByOpenMethod() from class "com.teamcenter.rac.aif.commands.open.OpenCommand" should be overridden
2. Following definition in kernel.properties (com.teamcenter.rac.aifrcpxxx.jar) should be overriden:
OPEN_COMMAND=com.teamcenter.rac.aif.commands.open.OpenCommand
Any idea how to override kernel.properties ?
The TC Doc contains steps to override .properties file to override UI components using plugin.xml by adding xxx_user.properties. But this approach did not work for me.
Any pointers ? Thanks!
