How to prevent access to custom Item type with Status for Particular role with ACL?
Hi all,
I want to prevent access to particular Item type (A2Part) having custom status (30-PreReleased) from Particular role (Manufacturing).
Can anyone help me in this?
Hrishikesh
4 REPLIES 4
Re: How to prevent access to custom Item type with Status for Particular role with ACL?
You want  to remove Read access?
Typically what we do is to remove all "Read access" entries from Has Status - "Vault" ACL.  (World -> Read = blank)
Then make a new sub branch under Has Status. Has Status (30-PreReleased) - with new ACL XXX_Vault_No_Read_Manufacturing_30PreReleased (Role = Manufacturing -> Revoke Read Access)
Place normal read access rules on "Working" ACL (e.g. world = Read)
see attached image
Yes but thats not how I wanted.
I want custom Item type having status to be blocked with read access from Manufacturing users.
Plus when it will have status 60-Released, it should be availble to Manufacturing guys with Read access only.
Hrishikesh
the method should give you the desired result.
Has Status (any status) -> Gives manufacturing read access
      Has Status (30) -> Removes manufacturing read access for status 30
      Has Status (10) -> Removes manufacturin read access for status 10
      etc for all statuses
POM_Application_object (Working) -> Gives everyone read access
        Has Type (CustomItemRevision) -> Remove manufacturing read access
This will lead to:
For Working -> remove manufacturing read access. World has read access
For status = 30 -> Remove manufacturing read access. World has read access
For status = 60 -> everyone has read access
You could also do it the other way around
Has Status -> Remove manufacturing read access
      Has Status (60) -> Grant manufacturing read access
Hi @mortenmoi ,
Could you please post snapshot of how to do this?
I have configured what you suggested but still not able to achieve it.
Hrishikesh
