Re: How to prevent users to login via thin client in browser?
@Roman65 has shown how to comment out the webclient correctly. It should not affect anything other than the http addresses that contain /webclient/* which http://server:8080/tc/service does not. The service URL should still function normally.
Evaluating: AW 3.4
Yes Randy...that is what i was expecting, but unfortuntaley it doesn't allow me to access http://hostname:port/tc/services. I am not sure why. But when i put back the old web.xml it starts working. Anyway the solution provided in te chat solves my current problem, but I was just taking the opportunity to clear my concepts as well. Thanks for all the suggestions
SRaj
I am trying to access http://tcremoteweb1:8080/tc/services
@Roman65 wrote:
As far as I know, it prevents only the webclient
what are you trying to call at http://hostname: port/tc/service ?
@Roman65 wrote:
Ok, I see
I can't help you with this, we don't have MRL installed
No worries :smileyhappy:...you, Randy and others have given me multiple options which has helped to solve this issue
SRaj
