How to "Recover" from configuration recovery state?
I am in the process of installing server extensions for Active Workspace. This failed in the process, and I suspect it is because of a server extension I chose. When opening the TEM in an attempt to deselect server extensions, I am only presented with a message saying that my configuration is in a failed state. Needless to say, it never recovers since the TEM never lets me choose other server extensions to choose, it always tries to recover the failed state with the same extensions.
How do I get out of the failed state?
Thanks.
Re: How to "Recover" from configuration recovery state?
