How to recover from corrupted AM Rule tree
Hi All,
AM Rule tree is corrupted. I am trying to import the backup file but it fails with error "The application is not privileged"
​Using the utility am_install_tree.exe to import with infodba user, mode=replace_all . (Have set env variables AM_BYPASS and AM_DEBUG to ON as suggested in GTAC)
​Error in the syslog is Error code 515003, +++Failed to set cut in AM_tree node 00007401
​​Tried to import the default file given in TC data as well.
​Did anyone face such similar issue, please let me know on how to resolve this.
