How to recover if tem.bat is deleted on TC client by mistakenly.
Hello All,
On my Trang Enviroment  I dn't know how tem.bat is deleted and without this it like a huge problem.
Can someone suggest some method to recover it.
Rathore
3 REPLIES 3
Re: How to recover if tem.bat is deleted on TC client by mistakenly.
You can grab TEM.bat from another client or you'll have to go back to the source media. Best is to reinstall unless you know for sure that TEM.bat is the only missing file. I suspect your virus scanner unless you're running a custom cleanup script which would need to be reviewed before a virus scanner (crap cleaner).
Evaluating: AW 3.4
Why dont you try copying tem.bat from another smiliar site. Most of the path definitions in TEM are Relative so it should not harm giving a try.
Thanks experts, copying the tem.bat from other site resolved the question here. thanks again for taking time to reply here.
Rathore
