How to remove naming rule while creating custom item
I have a custom Item and i have written a style sheet for it which is also follows
<?xml version="1.0" encoding="UTF-8"?>
Copyright 2009.
All Rights Reserved.
Filename: documentCreate.xml
Style sheet rendering for Item creation.
<rendering>
<page title="General" titleKey="tc_xrt_General">
<property name="item_id" />
<property name="revision:item_revision_id" />
<property name="object_name" />
<property name="object_desc" />
<seperator/>
<property name="uom_tag"/>
</page>
</rendering>
I have set both the preferences createrendering and create.registeredto perfectly.
I need help so that the item create dialog doesnt show me the naming pattern. I am using TC11.2 for info.
Thanks in advance
Chene
TC11.2 NX10
Re: How to remove naming rule while creating custom item
Did anyone know the solution to this issue. Please let me know. I tried to change the visibility in BMIDE and styleesheets renderingHint. Didnt get solution. Please let me know
Chene
I Havent found the solution to this issue. can anyone give some ideas please.
Chene
The name is mandatory, so it is not possible to remove it from the wizard
If your Item ID is auto assigned based on naming rule counters, there is no need to add show the Item ID property on the create page. So it can be removed from create stylesheet.
Mahendra
