How to restrict doing drag&drop on the Object.
Hi, I have a question.In the current system, we are not alllowed to doing the drug&drop on any object. I would like to see the setting file for it. Could you someone help me to find this setting file?
Re: How to restrict doing drag&drop on the Object.
Drag and drop is enabled (by default) in TC_PORTAL_ROOT\portal\plugins\configuration_XXXXX.X.X\portal.properties. You can override this setting in portal_user.properties. You can disable D&D for any object using GRM Rules in BMIDE. You can set the default dataset type using DRAG_AND_DROP_default_dataset_type.
Evaluating: AW 3.4
Thank you so much. I can understand it.
