How to revise Item Revision with using Workflow
Hi Experts,
I'm a beginner with Teamcenter and lerning to be good with teamcenter.
Have anyone ever created a workflow for creating an Item Revision before?
I have tried it for long time with many Handlers such as EPM-attach-related-objects etc. (form workflow designer guide) but it doesn't work.
If you all know this case please help me or give me a trick to solve this problem.
Ps. I'm using Teamcenter 10.1.5.1and Thank you for reading this post!
Best Regard
Nithi
Re: How to revise Item Revision with using Workflow
Unfortunately there is no OOTB action handler to revise an item revision.
Hi Nithi,
You could try to create a custom Handler which could revise the Item. ITK would help you.
Chene
