How to save query criteria in Structure manager search panel?
I wanted to save the search criteria which I give in the "Find in Display" panel (as in attached snapshot) in Structure manager application. But, I am not sure how to do this. I did go through documentation and found that in "Multi structure manager", "Structure search" option has the capability of saving the search criteria for future use. But, this "Strcuture search" isnt available in "Structure manager". I want to save the criteria given in "Find in Display" panel. If there is a way to do this, please do suggest the solution. Any help is appreciated.
3 REPLIES 3
Re: How to save query criteria in Structure manager search panel?
hi
1.- open search panel
2.- client on ... open attributes
3.- clic on button change
4.- on chage searh select system defined search
5.- select the search you want
6.- clic on change search
7.- clic ok
I thank you for your response. Could you please let me know, if there is a possiblity to save the query defined in "Find in Display" window. as shown in the attached snapshot. Because, here we can define queries on the BOMLine.
THank you.
I don't think that is possibly, maybe you can create a query in Query builder with those parameters and search the query into structure manager!!
Saludos,
