How to set different column configuration for different item types in structure manager.
Hi everyone..!!!
(Eg. Item type:- Marketing , Item type:-Sales        when I send Marketing (custom) item revision to structure manager it should show 5 column properties and
When I send Sales (custom) item revision to structure manager it should show 7 column properties in structure manager.)
Shailesh
Re: How to set different column configuration for different item types in structure manager.
Hi everyone..!!!
How to assign different column configuration in structure manager when different item types are sent to the structure manager.
Shailesh
Hello Shailesh,
The column configurations are stored as user preferences....you can have different configuration per user group etc.
I am not sure if you can have different column configuration for item types.
Harish
