Do you mean
Reply
Solved! Go to solution
How to set edit privileges by process ?
Hello, How to use the process to grant privileges on the ability to edit the revision of another user by the owner. I tried to use handler EPM-set-rule-based-protection by assigning the task to the end user, but got only the ability to edit a particular task.
SE ST9 + TC 10.1.7
Re: How to set edit privileges by process ?
You can set a workflow ACL on a task providing write/delete/change access to the "Responsible Party" as per attached screenshot.
Thx for help.
I try Yor solution but this dosnt work for me. I have task where I choose user hou whont to grand priviliges, in another task chose user is assigned and i this task i whont set privilages. I try set resposible party, task owner and it dosnt work.
SE ST9 + TC 10.1.7
Solution
Solution
Accepted by topic author Wollverine
‎09-09-2015 06:57 AM
Have you provided Read/Write/Delete access correctly ?
Also make sure that the ACL appears in the workflow task properties.
Acesses will be granted to user to whom the task is assigned.
Please check attached doc for details. If still you have issue, let me know if we can have desktop share ?
THX again.
My mistake was using task not do task. There are motod to grand edit privilages to other user not only on a duration of the process ?
SE ST9 + TC 10.1.7
