How to temporarily disable TC_customization_libraries
I would like to disable TC_customization_libraries temporarily when utilities are run.
I know I can remove the preference and add it back after the utility is finished, but that affects all Tc sessions, which is not good at all.
Does anyone have any better way?
Employees of the customers, together we are strong ;)
8 REPLIES 8
Re: How to temporarily disable TC_customization_libraries
Try removing those DLL from specific clients TC_ROOT\bin. I have done that and it works.
S A Saravanakumar
CBE, INDIA
Sure that is the other way, but this only works for 2-tier clients.
For 4-tier I can't do that, since the DLLs are used by other clients that should not be affected.
I like to have a solution that only impacts the current session, no previous or future session that might get changed/restartet while the DLLs are disabled.
Fur such use cases ( Utilities ) I use the following:
Set the environment variables
set TC_PREFERENCES_OVERLAY_FILE=Path To My XML File
set TC_PREFERENCES_OVERRIDE_FROM_FILE=TRUE
So the defined TC preferences from that file will be used.
I attach a sample XML file ( for TC10.1 ).
However, you can not influence a 4-Tier session in that way, but it is very useful when dealing with utilities ....
Thomas Zwatz, CADadmin, PÖTTINGER Landtechnik GmbH
Production: NX11.0.2.7 MP04 + TC10.1.7.1
Testing: NX12.0.2.9 MP07 + TC12.1.0.2
Unstable: NX1847
Development: C#
Thanks, that really helps to reduce execution time, since the customization slows down the maintenance utilities immensely.
In addition I will use that for installing or updating MRL, which can be done without any downtime, but customization also highly slows that down.
Rename your custom .so .dll
That is not really an option, if there are users still working on the system.
The way with the two variables allows one to just disable it where needed, without affecting the entire system.
Is there a way to avoid preference TC_customization_libraries for 4-tier session?
Thats Great.
Thanks Alex...
S A Saravanakumar
CBE, INDIA
