How to the BOM Lines from Structure with User/Group/Role Restriction using plmxml admin module
I wanted export the bom lines from the structure manager based on the user logged in Role and Group . How i can add that condition inmy closure rule? kindly help me on this
Re: How to the BOM Lines from Structure with User/Group/Role Restriction using plmxml admin module
you want to use plmxml utility, so you can use admin credentials for using this utility (user :-  infodba).
I think, in order to use export the structure by using plmxml, atleast you need to have read access to the structure, any child item to which you dont have read access will not be exported
