How to view NX drawings in embedded viewer
Hi guys,
My customer is using drawings as specifications under the item revision.
They want to be able to see the drawing in this specification in the embedded viewer.
Also the 3D model in the UGMASTER as well.
I've added the following under defaultViewerConfig
UGMASTER.DirectModelViewer=UGPART
UGPART.TCTwoDViewer=UGPART
Yes, I can see the 3D model of the part in UGMASTER but can not see the Drawing in the specification.
I also checked the Save Options
What am I doing wrong?
Cem
Re: How to view NX drawings in embedded viewer
Hello, what level of Teamcenter Visualization licensing do you use?
@CemAlpay, you've done everything right so far.
The next step is to modify some preferences:
1. VMU_Dataset = UGPART, UGMASTER
2. VMU_FileSearchOrder = UGPART, UGMASTER
3. TC_DIS_2D_named_ref = UGPART, UGMASTER
4. defaultViewerConfig.VIEWERCONFIG =
A. UGPART.TCTwoDViewer=UGPART
B. UGMASTER.DirectModelViewer=UGPART
C. UGALTREP.DirectModelViewer=UGPART
Restart Teamcenter and validate:
Click on a UGPART and see the drawing in Viewer tab
Click on a UGMASTER and see the model in Viewer tab.
Did all and now works!
