How to work with trunk/branches in Teamcenter
I'm trying to figure out how to store different design variants of an item within the same revision. Like working with a trunk (main design) an branches (design variants). Its should also be possible to merge a defined variant (branches) with the main design (trunk).
Are there any methods to do this in Teamcenter 10.1?
I tried several approaches with baselines but this doens't cover my needs completely.
Any ideas are very welcome.
Re: How to work with trunk/branches in Teamcenter
What you are describing might be "Branch Configuration" enabled by preference PSEEnableBranchConfiguration. It's part of BOM Variability. However the branching shown in the docs is with different revisions and not the same revision.
Another possibility is Intermediate Data Capture (IDC) but it doesn't support branching and puts limitations on your environment.
I haven't used either of these so to me they are theoretical. In other words, be careful out there on the fringe. You are wandering into territory few travel.
Hello Randy
Thank you very much for your fast reply.
IDC was also an possibility i tried out. But it wasn't the solution for my problem.
I will check out PSEEnableBranchConfiguration. This sounds, as you already said, more into BOM theme. This is actualy not what i'm searching for.
This need, to try out some different design variant during development activities, was already ask a couple of times by different customers. It's not that uncommon.
The need is not uncommon but the applications that I pointed out are. Good luck.
Randy,
I have long been wanting to do the Trunk / Branch in Teamcenter.  I thank you for the PSEEnableBranchConfiguration.
There are a couple of questions I have.  With it being its own object how does it work with the Structure manager?  Can it be used in say NX or just static document file?  I am just trying to figure the best use case/user requirement specification for utilization.
Andrew
Honestly, I don't know. In theory it will work with Structure Manager but I doubt it will work with NX unless you take care to rename the components/assembly for each variant. For variations in SM/NX I would use Baselining.
