How would I create these naming rule counters
I know how and where I need to specify the naming rule counters in BMIDE, but I don't want to split the complex counters into multiple simple ones, because it is not allowed to use regular expressions for patterns used with counters.
Here is an example of some of the counters I want to implement for the type Mfg0MENCTool.
Tool group ............... Start .... End
Spherical Mills .......... TL0400 ... TL0599
End Mills ................ TL2000 ... TL3999
Fix boring bars .......... TL6000 ... TL6099
Adjustable boring bars ... TL6100 ... TL6299
Reamers .................. TL6300 ... TL6499
Taps ..................... TL6500 ... TL6999
For example the spherical mills would be split into the counters "TL04"NN and "TL05"NN, where it would be good to use "TL0"%[45][0-9]{2} instead.
What would be the best and future proove solution to this problem?
Thanks in advance.
Employees of the customers, together we are strong ;)
4 REPLIES 4
Re: How would I create these naming rule counters
> What would be the best and future proof solution to this problem?
Use stupid numbers and move the intelligence (classification) someplace else.
Best,
/Randy
Evaluating: AW 3.4
We do use MTL and will be migrating to MRL in the near future.
We also talked to our machine operators and they wanted a rough classification trough the tool numbers.
If you're stuck using intelligent numbers then you'll probably be forced into a codeful solution involving user_part_no.c to implement the numbering logic.
Best,
/Randy
Evaluating: AW 3.4
The only way currently is to cheat and split text strings into multiple parts.
Example:
Tool group ............... Start .... End ...... Pattern
Spherical Mills .......... TL0400 ... TL0599 ... "TL0"NNN
End Mills ................ TL2000 ... TL3999 ... "TL2"NNN and "TL3"NNN
Fix boring bars .......... TL6000 ... TL6099 ... "TL60"NN
Adjustable boring bars ... TL6100 ... TL6299 ... "T""L6"NNN
Reamers .................. TL6300 ... TL6499 ... "TL6"NNN
Taps ..................... TL6500 ... TL6999 ... "TL""6"NNN
This is just an excerpt, so there are more tool groups, but you should get the concept.
