Http error 405
Hello;
I'm trying to install TC11.4.0.3 in a 4-Tier config.
I use java JDK u101. I also accepted default ports in installation procedure.
after building the TC web tier web application a deploing it in a web app I get Http "405 error:
HTTP ERROR 405
problem accessing /tc/webclient.Reason:
HTTP method GET is not supported by this URL."
I appreciate your helps.
Re: Http error 405
Good afternoon, what do you use as a Web Tier? J2EE? or. NET? Write what link you are trying to enter when you receive this error
Re: Http error 405
Dear Arthur3;
Thank you so much. it was a port confilict issue. I used another port and it is solved. thanks again.
