ICS_set_values_for_classification_obj error 71525
When I call ITK function ICS_set_values_for_classification_obj() the error_code check show
error 71525 The Attribute is not unique
Where is the bug?
Re: ICS_set_values_for_classification_obj error 71525
Good afternoon,
in the attributeNames array do not have duplicate elements?
No, all elements are different
And I also noticed that this function call dont change attribute value. But only this error appear, no any errors.
classification_user license used.
Try to pass functions only one attribute and one value, in which case the same will be an error?
I tried and  got other error: 71002 Missing Parameter :smileyfrustrated:
Give an example of how you call a function and what parameters you pass. Perhaps this is a Teamcenter error and it may be necessary to install a patch
Problem has been solved.
I made some code changes to fix it. Deep debug show the null value in attr_names array
