ICSXML / Export Classification
Hello everybody,
I have need your help Smiley Wink
I try to export automatically our classification but I have no the same results by an export manually since Teamcenter like an export with icsxml utility.
My problem is with this command: icsxml -file=classification.xml -filter=All -class=MRM -subclass -subclassview -subclassinstance -export
I haven't KeyLov on the export.
To have keylov, I must use this command:
icsxml -file=KeyLov.xml -filter=AK -objtype=A -objid=* -subclass -subclassview -subclassinstance -export
But I cannot found the right command to merge the data together. Have you a solution?
Thank you
PLM Technical IT
