ITK Based Custom Integration client
We have a project where we wanted to integrate Teamcenter Unified and a .NET based application. Is it possible to integrate both the application using a .NET based client which uses ITK API's and client resides in a different server other than the Teamcenter unified installation.
The examples that are provided shows custom programs can be written using ITK and C but it executes from the same server as the Teamcenter server.
Re: ITK Based Custom Integration client
hi @SISA10 & @tcsdcw, could anyone of you find out a solution for this problem ?
If yes, please let me know. Thanks!
