Icd file to delete old jar file
Builder
Builder
Hello admin
we have some old custom jars in plugin folder, which are pushed wrongly with wrong naming convention, is there a way we can delete them via icd file its self without doing a mannual deletion on each users workstation
Thank you
Re: Icd file to delete old jar file
Good afternoon, try adding an ICD file to the section:
<target name="file_download_win" depends="file_download_common">
</target>
the following tag:
<delete file="${PortalPath}\plugins\name_plugin.jar"/>
or a tag with a check that the file is available and only after that delete:
<if>
 <available file="${PortalPath}\plugins\name_plugin.jar"/>
  <then>
  </then>
</if>
