Import of Data (speech about weight from Item Master Form)
Hello! I need to import some data into Teamcenter from  Excel
FROM
TO
As i understand i have to use query builder. Help please!
Re: Import of Data (speech about weight from Item Master Form)
If items are already in TC and want to add to item/item rev, you can use live integrated excel to update the database,
If it is brand new, you can use add to team center. please give little bit more info, we can help you
Hello! Thanks for your answer! Yes, Items are already in TC. How can i use live integrated excel? Can you help me?
After installing MS office, there is utility(may be vjredist64) to be installed to integarate the MS offcie. Please get GTAC/Vendor to provide them.
Once install the utility, search item, select all items and select the detail tab, then export as excel which will give live integration option. it is dynamic.
Please check and let me know, if you need, I can send video.
Venny
I will grateful for video! Thanks.
Purple-doplhin
please send your personal email, I can shere
ddolphh@gmail.com
