Important: our company someone cannot login in Teamcenter by through apache proxy
Hello,everyone
       Some one caonnot login in teamcenter by proxy.
       By configuring the Apache proxy to achieve remote collaboration, some user can log in to the system, some cann't, the following error accurs:
then I check  the valiable FMS_HOME, picture like this
the find log like this :
2018-12-03_11h28_08.pnganyone can help me to solve this question? Thank you
9 REPLIES 9
Re: Important: our company someone cannot login in Teamcenter by through apache proxy
You can try deleting their client cache first.
C:\Users\<username>\FCCCache\ folder
If that doesn't work then compare the fcc.xml in the tccs directory against someone that works. Specifically the parentfsc address value.
Evaluating: AW 3.4
Hello,Randy Ellsworth:
     I delete the  client cache, Those person still cannot sign in Teamcenter.
    Then I compare the file fcc.xml in the tccs directory against someone that works, The content is exactly the same.
    It still not work .
    We are cross-domain access, configured with apache proxy according to the installation_client_windows.pdf. can you help me to configure apache proxy? or tell me how to configure proxy for Teamcenter.
   Thank you.
The next thing to look at then is the clientmap settings and if the client IP is included in the FMS Master. From the client that is not working, try this in a browser:
http://<server>:4544/configAvailableFSCRequest
If you see "webpage cannot be found" then you know the client doesn't belong to the FSC group. You will need to validate your clientmap subnet and mask settings to validate the client IP belongs.
The expected result is an xml showing the availablefsc address.
Evaluating: AW 3.4
@RandyEllsworth
for which version should this work? (http://<server>:4544/configAvailableFSCRequest)
tried in our environment, but I get the following result
HTTP ERROR: 400
Problem accessing /configAvailableFSCRequest. Reason:
    MISSING_TICKET_0
Hello, Randy Ellsworth,
         Thank you for your reply!
         In the brower, I input this address:http://<server>:4544/configAvailableFSCRequest,Whether it is a computer that can log in normally or a computer that cannot log in,shows that the webpage cannot be found. and I check the fmsmaster_.....xml and proxy, I didn't find any error, is there any other way can solve this question?? thank you for your help
It looks like the value should be "configAvailableFSCsRequest". You can read about it here:
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=configAvailableFSCsRe...
Evaluating: AW 3.4
Hi,Randy Ellsworth,
     I have look that page. Then I have tried in our system. In the Server. I changed value  "configAvailableFSCsRequest".it still didn't work
     I tried put http://host:4544/FMSMasterConfigFileRequest;
        http://FSC_Master_server:4544/configClientconfigRequest;
      http://FSC_Master_server:4544/configAvailableFSCsRequest
    All shows that "webpage connot be found"
     this Problem have been haunted for a long time, then I tried TC_ROOT\tccs\starttccs.bat,shows error like this:
can you help me analysis this log, thank you
You might be able to get a better message if you try a different browser. The browser you are using does not support frames and the xml is being displayed in a frame. The other issue I see is that the server IP versus the client IP are in different domains, as in 10.10.1.X vs 192.168.60.X. Crossing domains if the network doesn't support it can be causing an issue. Hopefully, you have the clientmap subnet 192.168.60.X and mask 255.255.0.0 specified in the FMS Master for the FSC you want to connect to.
Evaluating: AW 3.4
Hello,Randy Ellsworth,
        Thank you for your help. then I connect with Siemens, The Problem is that Proxy configuration.
       Now that all user can login system normally.
