Importing NX Cam template issue
We are trying to import the latest CAM templates, from NX 9.0.2.  GTAC suggested we delete the old templates, since they imported wong the last time.  TC admin selected the "NX9 CAM Setup Templates" folder, and hit delete, but it seems to only delete the folder, not the templates in it.  Is that how it works, we have to select each template, rather than whole lot of them in one folder selection?
-Dave
NX 11 | Teamcenter 11 | Windows 8.1
Re: Importing NX Cam template issue
You have to delete the Datasets first, then the Items, then the Folder. Otherwise you'll have left overs that are hard to find.
Evaluating: AW 3.4
