Importing Native NX data to Teamcenter
Builder
Builder
Hi Admins
Need help with question in NX Manager import.
In native NX, I have a Part with "front.prt", (I ahve like 100 parts in asssy), when i select the Part i want Item ID to be auto assign/generated from TC but Name should be taken from the existing OS file name
Currently when i select the data and click on Part ID Generator, it will fill Item ID and Name column with the auto assigned number. How i can control that auto generated ID shoul fill only Item ID and the Name should be derived from OS Part file nme
Re: Importing Native NX data to Teamcenter
As one option, you can use the Part Id Generator option, then in your prt you need to create the DB_PART_NAME attribute or another and fill in the name.
