Importing SolidWorks Models into Teamcenter with swimimport
Hello Everyone,
have someone ever imported Solid Works Files to Teamcenter? I have gotta to add 12GB of CAD files, around 5k Solid Works Files.
Thanks for helping!
Best Regards,
Re: Importing SolidWorks Models into Teamcenter with swimimport
swimimport can import solidworks models and drawings with a file list, that means you can import many sw files one time, but in fact, there is another limit that ,the sw can not release resources after one model opened and closed, so how many files you can import one time decide on your solidworks and your pc performance in the other hand;
I have tested this , in my computer , I can only import nearly 150 files one time, otherwise the import process crashes. you can test this within your environment, hope this information will help you!
