Infodba
Hi Guys.
I have admin rights to Teamcenter.
We have templates in Teamcenter and I want to revise them.
They are not releases but the owner is infodba and when I try to open it I get the 'save as / revise window'.  See attached image.
I only want to make a slight change to these so I do not want to do a new revision.
How can I make the changes?
I am in the process of doing a full overhall which I will add later.
15 REPLIES 15
Re: Infodba
try use bypass (work not only for infodba):
Re: Infodba
Hi Arthur.
It still askes about save as or revise.
Re: Infodba
Can you show us the 'Save as or Revise'....
Have you checked the dataset out?!
Rich
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
Re: Infodba
Hi Richard.
All I want to do is have it open with working sheet as default.
I want to open 000978/A
Revise / Save As
Re: Infodba
look closer at the screenshot you sent:
Rich
Richard Bennett
PLM Consultant
Re: Infodba
Hi Richard.
I thought I would be able to make changes because I am an administrator.
How do I change ownership.
I just get the copy option when I select the dropdown.
Re: Infodba
Re: Infodba
The dataset appears to be owned by infodba? Who are you logging into SE as? If you are a dba, then just make sure you are logging into SE using the DBA role...
Richard Bennett
PLM Consultant
Re: Infodba
Hi Richard.
Was going good.
I have made the changes I need, but when I want to chaeck it back in, it is asking me for unique identifier.
Its all greyed out and I cannot change it.
