Initialization failure while starting NX from teamcenter with "sslv3 alert handshake failure"
Hello all guys,
I have a problem which i haven't seen before. After i try to start NX from Teamcenter i got an error with "error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure" or in attachment and NX can't be started from TC anymore.
Nevertheless i still can use Teamcenter and Teamcenter integration for Solidwork is still working fine aswell.
Have someone experiences about this issue?
Thank you all in advance for helping me to solve this problem.
Ps. I'm using
Teamcenter 10.1.4.1
NX 10.0.2.6
SolidWorks2016
Best regards
plmLHT
Re: Initialization failure while starting NX from teamcenter with "sslv3 alert handshake failur
Good afternoon, try to see solutions from the solution center:
https://solutions.industrysoftware.automation.siemens.com/
Document ID: 001-7654102
Document ID: 002-8008664
