Install CREO and configure with Team center
Hi All,
Can anyone help me with how to install CREO and configure it(integrate) with Team center.
Any kind of help file available?
Kindly share or help me out.
GNR
10 REPLIES 10
Re: Install CREO and configure with Team center
Installing Creo should be fairly straightforwad.
iPEM is the integration sofware between TC and Creo. You should be able to download iPEM (assuming you have the license) from GTAC and follow the installation document.
If there are specific problems, post to the forum.
Yes, I installed Creo integration last week. All you need to get the IPEM file from reseller or download from GTAC, install.
There is installation manual in GTAC, just follow.
Now I am trying to figure out how to bring all custon item.. please let me know, if you need any further help
There is an Installation Guide, Admin Guide, User Guide and Release Notes provided IN the software. Install it someplace (even a throwaway) then you will see the PDF's in IPEM_DIR.
Hi MSS,
Thanks for the help.
Installed CREO with TC.
Do you know software for integrating TC with OrCAD?
GNR
Hi Venny,
GNR
Hi Randy,
GNR
https://www.plm.automation.siemens.com/en/products/teamcenter/design-data-management/ecad.shtml
Hi Randy,
Thanks again.
is It Teamcenter EDA?
Adding to installation of CREO and integration with TC,
If you want the JT translation also configured, you need to install JT translators and configure the dispatcher for translation.
You can download the guide for JT translation incase required
