Installation of TC 12.0
Dear All,
What diffrent in the TC 12.0 installation?
Can anybady give installation Steps or PDF or other help file for TC 12.0?
I have PDF files from GTAC server, but theory only.
Thanks & Regards,
Irfan Pathan
Re: Installation of TC 12.0
Is this for an initial installation or an upgrade (from what version)? Where are you stuck or what have you tried?
Evaluating: AW 3.4
Hello, Irfan.
You can view Teamcenter 12 help in HTML and PDF on Doc Center at: https://www.plm.automation.siemens.com/en/docs/tc/12.shtml
What's New describes new features in Tc12, including installation.
From the Tc12 publications kit on GTAC (Tc12.0.0.0_pub.zip), you can install the help locally using the help_install_instructions.pdf in the kit.
I hope this helps.
Kind regards,
Greg Bittner
