cancel
Installation with pre-configured data
Hi all,
I'm new to Teamcenter and I'm trying to start an evaluation of the application. I was wondering if, along with the normal installation package, there's a dataset containing users, groups and projects that can be imported and used as starting point to explore the different functionalities.
thanks, Marco.
Re: Installation with pre-configured data
In a normal Teamcenter install there is no such thing, I'm afraid. But if you can get your hands on Teamcenter Rapid Start. It comes with exactly what you want.
Good luck with the eval
