Re: Installing Teamcenter Rapid Start 11.2 - minimum Features
Hi Randy,
yes I thought so, but Windows surprise me in that.
Sorry it´s german.
And here the new rule (same for output-rule):
Best regards
Michael
Michael Eichelberg, CAD-Consultant, Dr. Wallner Engineering Nord GmbH
Production: NX11.0.2, NX12.0.2
Development: Batch and VB Testing: NX(1847, 1851, 1872)
You will likely need to open more ports when running the 2tier rich client, like 4544 and 1572 (there's more). If you decide to run a 4tier rich client then you might also need to define rules for UDP as well as TCP, like for RMI and OTWSVR.
Hi Randy,
Yes, I thought as much! Some days ago, as I test to install a 2Tier Rich-Client, I saw some errors with port 1572, ....Now I know why!
So I will try to find out all necessary ports to open, as well as rules for UDP and TCP. But I´m hopefull to have a running system soon.
Thank You!
Michael
