Integrate Teamcenter plugin in Workflow
How can I integrate Teamcenter plugin in Workflow. For example to use difficult check in workflow and accept or reject solution?
Re: Integrate Teamcenter plugin in Workflow
Good afternoon,
for these purposes, you can write a handler using ITK.
Please, can you write an example or post documentation for this ITK
ITK customization
https://docs.plm.automation.siemens.com/tdoc/tc/11.4/help#uid:xid1256877:index_itk:id921903
Example
https://docs.plm.automation.siemens.com/tdoc/tc/11.4/help#uid:xid1256877:index_itk:id921903:xid62913...
Workflow
https://docs.plm.automation.siemens.com/tdoc/tc/11.4/help#uid:xid1256877:index_itk:id921903:xid62934...
Customizing a procedure with EPM (Creating action handlers, Creating rule handlers)
Or if you have the downloaded documentation, see
server_customization_programmers_guide.pdf
find in the document: extern int cust1_action_handler
How to configure Visual Studio (for TC10) can be found here:
http://learnteamcenter.blogspot.ru/2016/03/itk-debug-configuration-visual-studio.html
