Integration of solidwroks with TC.
I am integrating solidworks with TC.
When I finished the necessary process and try to open the Solidworks in TC, the error message displayed, which says "Cannot set policy to swim_attribute_policy".
Could you tell me how to solve this error?
Re: Integration of solidwroks with TC.
Hello everyone.  I don't have a solution to the specific question below, but would just like to say that we are in a project now to integrate both Creo Parametric and SolidWorks with TeamCenter using IPEM and SWIM.  We've got a test server and a bunch of test workstations for the purpose and we're methodically working thru a bunch or use cases, refinining various configurations.  Would like very much to compare notes w/others doing similar.
thanks in advance
the swim_attribute_policy.xml should be in the %tc_data%\soa\policies folder
this is what it contains:
<?xml version="1.0" encoding="UTF-8"?>
<ObjectPropertyPolicy xmlns="http://teamcenter.com/Schemas/Soa/ObjectPropertyPolicy">
<ObjectType name="CadAttrMappingDefinition">
<Property name="attr_title"/>
<Property name="is_hard_coded"/>
<Property name="description"/>
<Property name="mapping_parts" withProperties="true"/>
<Property name="mapping_type"/>
<Property name="item_type_name"/>
<Property name="dataset_type_name"/>
<Property name="object_properties"/>
</ObjectType>
<ObjectType name="CadAttrMappingDefPartProp">
<Property name="property_name"/>
</ObjectType>
<ObjectType name="CadAttrMappingDefPartGRM">
<Property name="relationship_name"/>
<Property name="type_name"/>
</ObjectType>
</ObjectPropertyPolicy>
Thank you for all the answer.
