Is there a way to migration from SE BiPDM to Teamcenter?
Hey,
We know that we are facing a Insight transitions to Solid Edge Build PDM now.
But is there any way to migrate directly to TC with revision history?
THX
Re: Is there a way to migration from SE BiPDM to Teamcenter?
@MichalGrygonis  - directly no but it can be done. You have to extract the data and do a lot of work to massage the data to the point that it can be added to Teamcenter. Are you on the SharePoint Insight or the original?
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
Hey
I am on Share Point Insight right now.
Can you advise right way ?
