Issues while upgrading TC 10 to TC 11
we try to upgrade from TC 10 to TC 11. Using Tc11.2.0a_win64 installation files.
The TC 10 version is V10000.1.0.20130604.00
The upgrade process fails with FlexLM initialization error and it seems to be a problem with
one of the upgrade scripts requesting a license feature named teamcenter_author.
Our license server is just able to checkout a feature named TCUACAD_teamcenter_author.
Any experiences or suggestions in that issue ?
Please see also attached files.
3 REPLIES 3
Re: Issues while upgrading TC 10 to TC 11
There is a PR about this problem with the following comment:
Will be resolved by code changes made to the release of our product version:
The patch process will correctly handle the infodba user switch from Author to Admin in releases tc10.1.5_a01_1 tc10.1.6, and tc11.2.2
Are you able to go to 11.2.2 directly?
xtof
Hi xtof,
first of all thank you for your information.
I will try the upgrade directly from 11.2.2.
But what is a PR ?
if you open a ticket at Siemens GTAC it is first an Incident Report and if it is really a software issue it gets a Problem Report.
