Item and item rev name should be same
All
When we create item, Item and Item revision names are same, When I modify Item name, Item revision name is not getting modified as same as item
Is there any option/setting/preference? please help me
Venny
Re: Item and item rev name should be same
Select Item, and Item Revision, then right click edit properties.
Now select both Item and Item Rev names in that list, edit at the top, and hit the green check mark.
-Dave
NX 11 | Teamcenter 11 | Windows 8.1
thanks and it works
