JT Bidirectional Translator for CATIA V5 documentation & best (translation) practices
Where is the JT Bidirectional Translator for CATIA V5 documentation located?
Where is a published set of Catia V5 to JT translation best practices?
Re: JT Bidirectional Translator for CATIA V5 documentation & best (translation) practices
They are documented in the readme here:
Siemens PLM Download Server > Teamcenter Visualization > Full Products > JT Translators > Catia v5 > PLM_Components_JT_Bidirectional_Translator_for_CATIAV5_v13_0_README.txt
I don't know of a best practices guide but it may be available from the software once you download it.
Good afternoon, if I am not mistaken, the configuration of the translator should also be described in the TCIC documentation on GTAC Download Server
Teamcenter and Teamcenter Rapid Start -> Full products -> Integrations and Solutions -> CATIA ->
Teamcenter_Integration_for_CATIAV5_XX.X.X_Documentation.zip
The TCIC documentation talked about the integration but didn't talk about the translator.
Good afternoon Randy, I looked in the documentation, it has the following information:
Configuring the Theorem/Teamcenter Translator
https://docs.plm.automation.siemens.com/docs/tcic/12.0.0/doc/in_config_jt/config_jt.htm
Convert Items to JT
https://docs.plm.automation.siemens.com/docs/tcic/12.0.0/doc/convjt/convjt.htm
Maybe it's just the language then. The Theorem translator [TH22120] is a substitute for the TcVis [VS22105] translator for CATIA V4. For CATIA V5, the TcVis JT bi-directional translator [VS22196] and the import translator [VS22197] are provided by Siemens and not by Theorem. I assumed the docs were old news.
